There’s a few moving pieces. (sorry for the bad pun)
You can, optionally, mark up your designs to indicate that a certain dimension should be resized to equal the material thickness. “Make this slot as wide as the material is thick, plus 0.002” for clearance". That sort of thing. Plans we sell will be marked up like this. If you do this, as you say, you can swap 1/4 for 1/8 and it will still work.
When designing, you can designate “product” and “scrap” separately, so the laser’s kerf lands in the scrap. That way, puzzle pieces and other measured dimensions fit.
Hope that clarifies!
