This is a pin I designed to fit in the holes in the laser bed. I put these in place to align materials against so I can place them repeatedly in the same position.
Because the holes are irregular it will only fit in some of them and you may want to tweak it to fit where you want.
I am printing on a monprice mini delta in vase mode. The gcode for that is included.
Not permanent. But for example, I have used them to flip something over and engrave the other side. Or set material so it aligns with my SVG exported artboard.
