Interesting, I was trying to use the denatured the same way I was using dish soap and water: apply and scrub. I wasn’t aware it could just be a soak. Either way next go around definitely looking forward to the the sanitizer.
I wonder if blasting it with walnut shells will do the trick without ruining the design
But sanitizer gel works well Thanks for sharing
Those look fantastic! Thanks for sharing.
Wow, fantastic indeed!
I’ve never tried a 3D engraving, yet, with my Pro. Did you remove the proofgrade label/protection in advance? I will then try with the sanitizing gel solution…
Good question, and yes, for 3D engraves I seem to get better results by removing the masking from the engrave area first.
I generally find any sort of decorative engrave does better with the masking removed first. I pretty much only leave it if I’m engraving very simple shapes.
