Instead of just a handle to rotate an image, a dialog box where we could input the degrees we would like the object to rotate. There were times when I rotated it and it changed the size ever so slightly.
I have not had that problem so much as I keep the arrow away from the white dots but a real precision rotation much like the precision location data would be tremendous.
Yeah, you have to be careful when manipulating the file, so many times have I resized or grabbed only a portion of a file - only to be confounded with the print.
This reminds me of a feature I’d like to see: being able to lock out resizing.
In my workflow I often want to rearrange parts to fit on partially used stock. I (almost) never want to resize.
Oh oh oh! Me too, Mr. Cotter!!!
Thanks for the suggestions! I’ll make sure the team gets them.
In the meantime, there is a way to rotate a design 45 degrees. You can find it in our keyboard shortcuts article.
