Thank’s for this link to the Auto Heat Press xTool! I’ll check out this machine and see if it can speed up some of my workflow. I haven’t seen this before. Thanks again!
Wow, that IS a lot of work, and much more than I’d have time or energy for. Thank you for sharing your process! And until you find a machine to help cut down the time for you, your results are still amazing!
Thanks for these comments! Seeing children and adults break into a big smile as they touch one of my embossments makes it worthwhile.
I have a WonderPress (but haven’t had a chance to use it). The vacuum forming module works with thermoplastic sheets that form around a physical shape, to make molds. The molds work well to make custom packaging or to make objects with things like chocolate, ice, candles, soaps, resin, etc.
My understanding is that it will not work with paper.
I have worked with Thermoform sheets and they usually provide fewer details than I can get using paper. Interestingly, some children who are blind don’t like the feel of these plastic sheets as much as the feel of paper. Thermoform sheets are great for making graphs and designs where raised lines are primarily used. They are also used in scientific texts.
Yeah - that makes sense!
The WonderPress works well for lots of things but a project like this may not be the ideal tool.
That’s interesting that the blind don’t like the feel of plastic sheets as much as paper. Any idea why?
Huh. I would have thought you could put the paper inside the plastic!
I’m not blind but I to hate the feel of plastic on my fingertips. I imagine, especially as your trying to feel so the details, that feeling would be a hundredfold.
I’m not really sure why children who are blind prefer touching paper instead of plastic. The director of the Louis Braille School in Edmonds, WA – where I volunteered for a while – told me this. From years of her teaching braille to children, she said that some children even refused to touch plastic pages with braille but would touch paper pages with braille. I’m guessing that it has to do with the kind of softness that paper conveys compared to a more rigid, slick feel of plastic.
That’s one reason I continue to use paper, sometimes thin for holding more details, for my embossments. From experience of making some embossments in plastic (or polystyrene), I also prefer the touch of paper and will keep using it in designs.
Paper is more tactile. Much nicer than plastic.
Thank you @jimballard for your detailed write up. Congratulations on your project.
That’s really interesting! I never thought about this before, I just don’t have any experience in this area. But it makes sense to me. (I have a tween with Down syndrome and medical issues, and she is very particular about certain things. Not always things I expect or things I fully understand!)
Makes a lot of sense that paper feels much nicer. I know our oldest daughter can’t stand the feel of certain materials, like crepe, suede, velvet, etc. She’s in her 50s now, and still can’t stand those materials.
This is truly amazing @jimballard . I would like to try to do some embossing using this method. Just not sure right now what I would use for a vacuum without buying a new tool. Three of my grandchilden love making things and I can see them liking to experiment with this. They are teenagers, home schooled and do a lot of homemade type things so this would be up their alley.
If you want the teenagers to experiment with raised paper surfaces, you might try this: use a computer mouse pad that is fairly dense. Place a piece of paper – maybe cardstock, Bristol or Canson Multi-Media paper – on top of it. Use something like a bamboo skewer, blunt pencil tip, or even the closed end of a pair of scissors and press fairly deeply into the surface of the paper. Once the paper is turned over, you will have nice, raised surfaces matching the lines you made on the other side. You could even run a piece of paper through a printer to create intricate patterns, like the details of a dragonfly’s wings, and trace that pattern!
You can also use silicon pads that Walmart and other stores sell for less than $8.
You can made detailed designs with this technique and you won’t need to buy a lot of new equipment. This is a method that children and adults who are blind often use to make their own tactile drawings.
Great idea, thanks for the info. I have several silicon pads we could use…and watercolor paper!
