I need another feather box and one for the pvc rocket bodies, still.
Uniform size and shape will help my closet and the next Cubmaster’s.
Small enough to organize all the things, but long enough that nothing needs to be stuffed in the back, lost, and repurchased.
Laser all the things.
Q: will you take the Cubmaster job?
A: if I can use my laser.
Q: can you come to a birthday party
A: laser-made and laser-enhanced gifts!
You could have a tab that protrudes upward on the lid and a cavity on bottom of the one above it, so the Boxes would lock into each other. Just an idea that might make it look more organized.
My 1/8" Baltic Birch is pretty inexpensive, and really is 5’x5’ sheets of imported stuff.
There are occasional knots in the inner layer, so it isn’t grade A. In the last five 20"x12" sheets, I have encountered one knot that messed up a cut. I’ll take those odds at this price.
These boxes are 13"x4"x6" inside dimensions, so 1/4" bigger all around.
I could work with that if it comes to my door instead of me having to pick it up. (Small car.) I could probably manage 5X5, and I do have a cheap recip saw for cutting to manageable pieces.
I love this so much for organizing!
It is so cool how you can engrave what the contents of the box are. And if you needed to change, you could pop the box apart, put it back in the GF and away you go. Brilliant!
