Used my GF Light Saber to cut the leather pieces for this A5 Journal cover. In the process I has to develope a format for testing leather cutability and try several several type faces to determine which would make the best holes for hand stitching Enjoy
Oops, meant to include this variation of something else posted. I use small pieces and run the test on both sides since there seems to be some variation in my limited experience
If you upload an .svg the image will default to a 1x1 square - but you can manually change the file size in your edit screen - though if you’ve got a raster in your .svg it deletes it…for some Discourse reason
