I noticed on the last piece I made that the adhesive pattern actually showed up thru the white acrylic. My question is this, what are you using to attach acrylic to draftboard ?
There have been a few threads about this, ought to have you covered:
These and more here:
https://community.glowforge.com/search?q=Acrylic%20wood%20glue
what I’m looking for is an adhesive that will not show thru a piece of white acrylic
They’ll all show through in some capacity - what you need to focus on is having the join be even so it looks shaded rather than wiggly lines or whatever. Tape makes that easiest since you can cut it to the exact shape, but it’s doable with the glues mentioned as well with some patience.
