I am trying to make the basic shapes for jewelry. Like blanks that I can customize and change the type & decor to spec.
I finally rendered a cut path using the pen tool around the shape which fixed the problem of the intersecting shapes ( the heart and the Bale) from creating two cuts. It turned out jagged. I do have snap setting turned on.
The plain heart is the Jagged one.
The one with all the jazz is the one that I was trying to build but could not get all the extra lines out.
Add a circle for the hole, then select both the heart and the hole (cmd-a), then select Layer|Geometry|Combine. The two objects combine into a single object. You can deselect it, then re-select and change the stroke color to verify they are really one object:
Just an aside, in case you forgot…remove the fill in the heart AND in the ‘hole’ … just leave the stroke. And something else just because I’m curious…why are you using the IOS assets panel?
iOS is the operating system used by iPhones & iPads. The asset panel taking up the lefthand portion of your screen contains pre-drawn objects useful to mobile app developers.
The same answer as Dwardio, but if you are designing apps for iPhones or iPads, that’s the panel you would be using. Otherwise, you can just use the regular toolbar down the left side.
[/quote]
