Export as SVG, upload to GF and the ‘empty’ parts of the letters are filled…
This doesn’t happen with all fonts, which makes me think it is an issue with the shape not being closed. I can’t for the life of me figure out how to fix it. I would love any help to get this fixed…thank you!
I need to start rasterizing. I have always done vector engraves because it’s easier to set up, at least if you don’t have issues like this. I would have to re-develop settings for rasterized art, so I keep putting it off…
I think that the linked thread contains the information needed to solve your issue, but I am curious what would happen if I opened/resaved the file in Illustrator. I doubt it would fix the problem but it is easy to try…
Do you raserize to a particular DPI? It seems I often end up with ‘fuzzy’ edges when I try to engrave raster versions of the fonts. The vectors are nice and clean and crisp.
Minimum 300 PPI. If it isn’t something big, I will do 600 PPI. Just have to be careful of file sizes. Haven’t pushed the limits in a little bit, but I seem to remember around 25mb being the limits.
You might be able to get around this by linking the rasters instead of embedding, as I think it will ask you to upload each linked raster one by one.
