Add 2 different files at once
Is there a way to add to different files at once to cut or engrave. I created 2 items at different times and now I have an order for both. is there anyway to add them both at the same time?
Click on the (+) to upload one. Then repeat for the other.
Since you created the files, are they on your computer? If so, simply open one and add the next. If they are both in your Dashboard only, you will not be able to open both from the Dashboard. Export one and then add it to the other that is already open.
Thank you. Still learning every day. Thanks so much
Thanks so much. Fully understand. It will save me the extra steps.
