Hi all,
I am hoping you might be able to help out. I have done some searches and tried to find any videos that may assist in the problem I am having.
I am using Affinity Designer to do my design work and import into GFUI with either SVG or PDF format. I created one file that is my set of letters for a phrase to put onto a sign. I then created a second file with the same phrase and the text formatted to be used as scoring on the sign so it will help with placement.
I have converted the text to curves and it mostly works except for a few letters that are having issues. Letters such as âoâ and âeâ do not work with SVG properly imported into the GFUI. I converted to curves I removed all the fill on the letters and just have an outline.
When I converted to a PDF it solved the issues of those letters but the âsâ is filled and has a line as seen in the attached screenshot.
Any help would be appreciated. I am a newbie and have only used the machine less than a dozen times so I am still trying to get past some of the annoying format nuances.
Thanks!
Jim
