Hi, anyone know the CFM of the air filter unit by itself (not including the fan inside the Glowforge itself)?
Thanks!
Thanks!
Just guessing (I don’t use the filter) but the exhaust fan in the laser moves around 200 CFM, and there is a switch in the UI to tick if you are using the filter to disable the internal exhaust fan - I’m thinking it must be in that neighborhood.
There is a dial on the filter to increase the fan speed as the filter loads and restricts the airflow, so it’s variable.
