You can uncouple the elbow and switch to the vent - that’s just the physical connection.
I think the problem is the same as with the Compact - the laser unit knows the filter is attached. In the case of the compact it’s told in the software so the fan control can be modified. I seem to recall that for the GF it’s electrical not software (RF maybe?) that tells the GF that the filter is attached and to turn off the main fans and turn on the filter’s fan.
Just unboxed the Compact Filter. My initial thoughts:
It has wheels! How cute.
Oh neat, once you take the lid off, the filter comes with handles for easy removal.
OH WOW. The filter itself is way bigger than I thought. This is not your window air conditioner’s slide-in filter.
There are some funky design choices here. The power switch is on the bottom corner of one side, and the fan controls are in the middle of the other side. The intake is in the center of the top. This makes it very difficult to figure out what orientation I can put this darn thing.
Would make a lot more sense to have the fan controls and the power switch on the top.
The power cable that comes with it is WAY too short. Eyeballing, it’s maybe 2.5 feet? And given the weird orientation choices I’m forced to make due to the above design decisions, I definitely need to replace it. Luckily, it’s a very standard 3-prong power plug, like any desktop computer would have.
At low fan settings, it’s approximately the same loudness as the Glowforge, although it’s a deeper sound. When the Glowforge is running, it’s not noticeably more noise than without the filter running.
At high settings it’s real loud!
I’ve only done one short test run so far, but overall seems pretty cool (annoying design decisions aside).
(Important to point out this wasn’t designed by Glowforge, so you can’t hold them responsible for the weird design choices.)
yes, this is the big issue. if you just disconnect the hose, the fan won’t be running. hence my comments about people discussing ways to mod to override that RF when you want to use the vent instead of filter. but we really won’t know how feasible / easy that is until someone actually has a GF filter to test.
It’s relatively easy to switch between either filter & a hose. You just turn off the filter, disconnect it, and connect the hose.
The thing that is hard was that someone wanted to connect their filter to their Glowforge, and then exhaust the filter outside. That is, send the clean filtered air outdoors. I don’t know why you’d want to do that, but it wouldn’t be particularly easy.
I believe that is the case Dan was responding to in specific. The official under-unit Glowforge filter system.
It connects on the same exhaust port as your hose would connect, but with a little C shaped connector which diverts the air straight down and back into the filter. You would pull off this connector, then attach your hose, and now be able to vent out the window.
With how small of a lip you have to connect the hose, some people have built extensions to make attaching a hose easier. Those extensions would interfere with connecting the official filter. Those who want to regularly swap between venting and filtering will have to deal with the really small connection lip for the hose each time. (Maybe I am just an oaf though, and for others it is not problem getting a good seal there)
Yay! Then I’ll probably wait for the Glowforge Air Filter. The only reason I might have considered switching to the Compact Filter would have been if it would be significantly harder to switch between filtering and venting outside with the Glowforge Air Filter.
Thanks for the clarification. That might have changed my decision, but (so far at least) I’m happy with the decision to swap for the compact filter.
Could you also clarify whether or not the Forge has to be taken off the (official) filter to change the cartridge / consumable filter, or if there will be easy access to replace a “used” filter with a new one while the 'Forge is still on top of the Filter?
I’m strongly considering switching for the Compact Filter, and while we haven’t heard of replacement costs yet for the filters, will they be available any time soon? I’d hate to get the compact now and then not be able to switch it out any time soon when it fills up
how high would you have to lift the Glowforge to change out the filter? I am wondering about some Glowforge made stilts that would hold up the machine while changing its diaper, is it possible to add that to the design of the diaper at this stage?
