Air filter question
I have to buy a new filter already. Can I use a compact air filter in my glowforge air filter? The one I was going to buy is sold out.
Thanks
amy
Yes, I believe I saw recently that they are interchangeable. (The Compact filter doesn’t last quite as long as the Glowforge filter cartridge though.)
Thank you!
Ouch. If there were any way to vent outside you could save that expense. :grimacing:
@amyellis We’re currently sold out of the Air Filter cartridge. While we work on getting it back in stock, the Compact Filter cartridge will work. This cartridge is compatible with your Air Filter and can be easily installed using the directions in the Air Filter manual. One thing to note, the original cartridge included with your Air Filter lasts up to 20% longer than the Compact Filter cartridge
