For the last 2 days I’ve been getting an Obstacle Alert. No obstacles in the machine. I shut down and restart and sometimes it will return like normal to try to center. It does not successfully center. Instead the print head goes all the way to the right, hits the end of the arm its mounted on, makes a grinding noise and I get the obstacle alert again. Please help. Thanks.
Just saw this one recently.
Yep…here it is…
Yes, originally I received the “Bumped” warning, then it just switched to obstacle. I did that and it seems to be ready. I also took the opportunity to do the maintenance cleaning - it was pretty grimy inside. I’ve shut down and restarted twice now to make sure it is good, and it seems to be. Thank you for your help. I’ll let you know if for some reason the problem returns.
Noah
Thanks for the answer @Jules, that’s right. I’m going to close this thread - if the problem reoccurs, go ahead and post a new topic. Thanks for letting us know about this!
