I searched a little in other posts but didn’t find a solution.
The X axis of my unit is always off from the camera view. There is a small problem with the Y axis.
One pic is a screen shot from my PC. The other is a photo of the actual cut. My projects always end up about 1/4" off. I thought I could make a shim to fake the head into homing 1/4" to the right. There does not seem to be a limit switch for home like my 3D printer uses. If worse comes to worse I guess I could start my projects aligned on the right of the material and move left, or make a shim to put on the material that is the width I need to compensate for.
Maybe I am just too picky with putting the cuts right on the edge of the material.
Thanks
