Hello GF team! I’m having the exact same problem as described in this thread:
Namely, no matter what I do, the GFUI shows the “Lid Open” message in the upper right corner whenever the GF is powered on. Normally, when powering on the unit, it will do the standard calibration procedure. But since last night when I printed my last job, it has consistently indicated the lid as being open, and the calibration procedure also does not occur. I’ve cleaned the crumb try area and door hinges, and checked all the alignment as suggested in the above post. Everything looks fine.
What can I do? Did you guys learn anything from the last case that might be helpful in further troubleshooting this one? Perhaps if I knew a little bit more technically about how the lid open detection actually works, I could troubleshoot a little further.
Thanks,
Ryan
