Hello everyone
I made some soccer style earings from proofgrade acrylic. I have just started trying to use glue with acrylic
I did a search on this forum and found that E6000 is good.
I have used CA glue on wood and abs which works good also.
Here is where it gets different
The pieces you can see in the pictures are really small, so to get a rough edge on those small of pieces is going to be tough.
I was wondering about doing a 2 part epoxy and pouring it over the top of the earings so that it seeps in between the cuts to create the bond.
The ones in the pic are done with gorilla super glue I glued over the masking tape to allow the glue to seep in between, which it did, but getting the masking paper off after proved difficult. It left scratches and looks as the glue may have damaged the acrylic.
I would like to hear everyone’s input and feedback and if a better solution is available I would like to hear that also.
Thanks a bunch
Bernie
