We’re sorry, an error occurred while preparing this print.
If the issue persists, please contact us at support@glowforge.com with details about what’s causing this error to occur.
File attached… One engrave object, one cut object. Engrave set to Photo. Nothing special (aside from the fact that it’s for my daughter’s birthday tomorrow). Jack Kelly2.zip (519.3 KB)
It sits on the Preparing your print / Preparing your design window for about 6 minutes, then errors out… every time. Rebooted, even tried deleting and re-uploading the file.
No, it might have already been at that res…if I see a file that covers that much of the bed, area-wise, I automatically drop the image resolution to 72 ppi in order to drop the pixel data load, first thing. (I do it in Illustrator and it doesn’t show what it starts out at.)
If someone is having trouble with one that is about half the bed size, I won’t drop it quite that far…might start with 300 ppi.
It’s just a first step I do to reduce load. Wasn’t needed in this case.
So I got the photo to work at 340 LPI by separating it from the text. 1.3 hour engrave. The text and cut are running right now. Will be another 1.3 hours.
Glad to hear you were able to get it printed, thanks @jules for the help! I’m going to close this thread but if you have any further issues please let us know.
