I need a single-piece short phone stand that I’d be able to put away easily, and while there are a bunch of great designs on here including another with a living hinge, none did quite what I was looking for. So here’s mine
Best bet is not hardwood - it broke no matter which way I tried it.
I also made one from leather that works but is a bit too weak (I may just glue some support wood to the inside)
The opening fits a phone up to .75" thick (or a normal phone in a hefty case).
I had considered alternating the height of the lines as well, but wasn’t sure how that would affect the hinge portion I keep on saying that at some point I’ll sit down and do a bunch of testing, but so far… not so much!
I would think carefully gluing the leather to the plywood living hinge would work well. I use spray 3M adhesive sprayed on leather or cork fabric to re-enforce my living hinge purses.
