Antenna?
Ball link piers.
Ancient medieval torture device.
Chinese tile cutter!
Homemade metal tamping/hammering tool.
Flywheel pulls the leaf springs up, pulling the hammer up and then pushes the leaf springs down, pushing the hammer down and softening the impact on the entire frame.
Is it used with forging swords (the Oriental symbols)?
Is it used for setting stones?
Sizing mandrel?
Ring Stretcher?
Ding DING DING.
Its a power hammer. Of the home made variety.
Commonly used in blacksmithing. The leaf springs allow for different size stock to be hammered without jamming the machine.
Smoke sifter…
It’s a Sharpie !! Used for permanent marking !!!
@tom gets it (although @Jules may have meant the same thing?).
You drop the ring over it and tap the tapered shaft into the split part to stretch a ring.
I was a jeweler in a past life,
I also like the idea of ring stretching… but im not sure how you would get the inner mandrel out if you pounded it on with a ring on the outside… and between the two pictures it doesnt look like the outer tube expanded much…
So i vote that its a… mandrel for a small jeweler lathe.
edit: i need to refresh this page more often…
Chuckle! Yeah, I’ve got one, but it’s not nearly that nice. (Harbor Freight I think.)
My sister collects poison rings, and I got one for her once that was a bit too small. Used one of those to enlarge it.
We have a winner!
Those were reasonable reservations, but…
With the shallow taper it requires a surprisingly small amount of hammer force to stretch a silver or gold ring. The inner mandrel is also a bit longer then the outer one so you can pop it out by tapping the small end.
Had to look that one up and ran across a list of modern-day uses for poison rings. Now I want one that holds a spare hearing-aid battery!
Trivia question of the day – What 1960s superhero used a “poison ring” on a regular basis?
