Wondering if this is an issue across the board, or if it is just my machine.
I’ve been in the ‘queue’ with GF customer support for the last 30 minutes and still in position #4 which is frustrating. AND their customer service phone number just leads to a voicemail saying they basically don’t ever call people back.
Anyone know of a solution to get it working? My wifi is working fine. I’ve turned the machine on and off multiple times. I’ve refreshed and restarted my browser. Any other ideas?
Really disappointed in the lack of available customer support and second guessing myself on why I purchased it. Would love any support I can get!
lol you are right, My brain stored that earlier as being 12 noon for some reason. I think i was reading it at 2:30 in the morning tho which might explain things
They don’t have a “customer service phone number”. Where that’s listed on the website it literally says “Finally, if you’re curious what our voicemail message sounds like, you can find out at…” They’re very upfront about it!
Hopefully one of the tips @geek2nurse linked to will help you sort your connection issue!
I finally got it to work after 2 hours. Multiple restarts, unplugs, cleanings, refreshing browser, restarting computer, pulling tray in and out. Only to discover now that it’s printing, that it won’t accept any SVG files. I had to convert all of my prints over to PDF which is crazy because all of the SVGs worked yesterday.
And @deirdrebeth - yes, they are up front about their number. I just think it’s crazy to spend so much money on a product, and not be able to get a hold of a human.
I’m so sorry to hear about the trouble with your Glowforge. I have followed up with your email about this as well.
Your Glowforge was able to connect successfully to your network, but it may be having trouble maintaining a stable connection. When this is the case, you won’t need to go through Wi-Fi setup again, but you may see an “Offline” message.
Turn off the computer, phone, or tablet that you’re using
Turn off your Glowforge
Unplug your modem
Unplug your Wi-Fi access point
Wait one minute, then plug everything back in and turn them back on
Improve the signal path between your Glowforge and your Wi-Fi access point
Wi-Fi signals need a clear path. Remove physical barriers, and move devices closer together:
Move your Wi-Fi access point up high and make sure it’s in an open space. Avoid locating your Wi-Fi access point on the ground, under a desk, in a cabinet, or in a corner where its signal can be blocked.
Relocate your Wi-Fi access point closer to your Glowforge
Move your Glowforge closer to your Wi-Fi access point
Install a Wi-Fi range extender closer to your Glowforge
Run an ethernet cable and install a second Wi-Fi access point next to your Glowforge
Reduce electronic and Wi-Fi interference
I hope this information was helpful. Please let us know if you are still having trouble.
I appreciate your response, @chelsea - and replied to your email. The issue is not with my wi-fi. There is a strong signal (and it’s not far from the router) and the only other device connected to it other than my computer is my cell phone.
You cannot judge the GF connection with other devices. We have found this over and over again. If you haven’t done the troubleshooting steps already, I strongly suggest you do them. I actually suggest you take it even further and turn off your entire network by unplugging everything. Then start from the wall and plug in the modem and let it fully boot. If you have a separate router and/or WiFi access point, move to each of those in turn. Once they are fully booted, turn on your PC. Let it fully boot, and then turn on the GF. If you still find a problem, let support know what you have done.
These steps have been shown to resolve this type of issue pretty consistently which is why Support has asked you to perform them.
To reiterate, even though your PC/phone has a strong signal it doesn’t mean the GF does and it doesn’t mean your WiFi is working properly with the GF.
Mine took me 2 hours - and then I still have had issues on and off. Basically do all of the trouble shooting multiple times - it’s faster than trying to get a hold of someone in the customer service queue.
Clean camera.
Empty tray.
Clean tray.
Turn off machine, then turn on.
Unplug machine and plug back in.
Refresh browser.
Restart computer.
Test wifi connection (unplug, wait 10 seconds, re-plug back in - or move closer to machine).
Perform voodoo magic and do an interpretive dance.
Light everything on fire.
Find a new hobby.
Well, maybe those last few aren’t completely needed, but they are tempting.
I’ve used the same wifi connection for two years, but it would not run the calibration process on it. I even bought a “wifi extender” and that didn’t help. Since I figured out that was the problem (and set up a temporary router to run the calibration), I’ve been back to using it (the same old connection) without issue.
The point is, restarting or having “a strong signal” doesn’t mean it’s not the issue. If you can set up your phone to be a wifi hotspot, you can at least eliminate that as the problem.
haha… i love it! We’ll see how legit my interpretive dance moves are soon! Thanks for your response everyone… cross your fingers for me, I need to STEP AWAY from the scene for a bit before I lose my mind and grab the matches :}
I appreciate you mentioning this! My GF is back up and running. And this is the first time I’ve ever had this issue in the two months of owning it (no issue with wifi before). Hoping today was a fluke and I don’t have issues again.
And I’ll definitely look into it more if it comes up again! Especially if your extender didn’t help - but it might be worth a shot if that really is the issue.
Thank you!
