Any chance that the outline when loading a new job to cut could be changed to maybe yellow or white? Many times I can hardly see the object to place against certain backgrounds.
One addition that would be awesome is a simple line tool. When using the pass through it would be nice to be able to draw a cut line across a panel so the laser would cut off the work that was just done. Then remove the job and push more product into the laser.
I have found it a good thing to use white tape or white paint on pins and magnets as with smoke stain, black crumb tray and black magnets it is pretty hard to see anything. a bright LED flashlight handy can make the surface brighter to see what you are doing with alignment easier. I saw somewhere where there were light crumb trays available at one time. and that would make a world of difference as well.
JBV Yes, I do the same. Would prefer a simple line tool in the user interface.
rbt I still think it would be difficult to see on the computer screen. A simple solution is for GF to simply change the initial color or allow user selectable colors. I would also find it easier if when dropping a graphic in place to cut that it dropped where you place it and not in the top left corner.
All I’m suggesting is a couple of very simple things to implement that would make a big difference for ease of use.
The ability to select your own color for engrave and cuts in the GFUI would be great. I have asked for it before and will ask for it again. There is just something about the colors that makes it hard to see. Especially the grey.
