Hello, I have the Glowforge Plus. I have had for just over a year and I love it.
However the laser arm is remaining in the middle of the bed when i first turn it on. It seems like the print head does not go all the way over to the right during it’s start up test. It sound like the motor that moves the print head is sticking.
When this first happened, I was not to concerned because I turned off the machine moved the laser arm gently back to its starting potion. I then moved the print head to the right stop position and then back to the left stop position. Then when I turned it back on, it would run through it’s startup procedures correctly.
This would happen every once in awhile. Now every time I turn on the glowforge this happens. The noises are getting louder too.
What to I need to trouble shoot this problem and fix it before my wonderful GLowforge stops working.
Thanks
Nina
