I need some 1/16" ply, so I may make it down there.
That “aircraft grade” stuff can get expensive, because of its application, it could be considered “proofgrade” because of its consistently.
I don’t know anything about the glues or finish used, but it would probably be the strongest 1/16" to be found.
2’x4’ piece is about 23 bucks on the 1/16th I think. That comes to about $3/sf. Not like the great price you get for 1/8 baltic (something like $0.60/sf), but a good bit less than what you’d pay for common 1/8 hardwoods, maple tends to run about$6/sf.
I have a direct need for strong 1/16th wood, so this price is within range.
The aircraft grade plywood uses exterior glue and it is much more difficult to cut with a laser than interior glue used in the typical birch plywood. It also has additional certification over birch plywood made with exterior glue and not considered aircraft grade.
This is 1/16th ply. I don’t think I’ll have trouble.
