This corona spring I finally finished our bathroom cabinet. It’s a combination of the glowforge and shaper tool origin. The cabinet is made from eco 6 mm mdf painted black, colored mdf from forescolor 5 and 8 mm and 4 mm birch plywood from Koskisen. In Europe we’ve, at least had, to find our own materials…
I need to point out that I don’t have any experience of woodworking so I’ve just had to figure out things my way and sometimes read up on it. Through the forum I found maker case.com where I got the blueprint to build further on in illustrator. So far the cabinet is working at least!
There are a few scored lines to indicate shelves. The rest is inlay. I must say it is surprisingly easy to make… but sure, sometimes there are gaps when its a lot of cuts even though I sometimes compensated for it.
