This might be hard to describe but I’ve been doing a project that involves engraving, airbrushing the engravings then cutting out the shapes.
The problem I ran into is that from previous cuts, small amounts of wood, tiny cutouts as well as essentially dust/ash has collected in the pieces of the honeycomb of the crumb tray that has the support cross sections holding it up, the part where they don’t just fall through.
This area then creates a small fire that comes up through the cut and scorches the top, discoloring it.
You can try:
Strong vacuum for the ash.
Forceps or other extremely skinny tweezers for loose bits.
Gorilla tape affixed to a thin skewer with the sticky side out.
I use one of these though and it works pretty well for unsticking little bits that have gotten jammed in:
Thanks for the ideas. I think the issue is that I haven’t been vacuuming out well enough and it’s become, for lack of a better term, gunk. I’ll try flipping over the crumb tray and keeping it clean.
You can get the same tool @Jules listed at Harbor Freight in a set of 4 or 5. They should be with automotive tools I think. I call them automotive picks. Straight, 45*, 90*, and offset angles.
