I can’t select the artwork or move it and the bed image doesn’t show up. This happens every once in a while and eventally I give up and come back later to a working UI.
I have
rebooted machine,
rebooted computer
opened and closed lid
deleted caches
entered material thickness (this did once show the image but then wouldn’t work)
I haven’t tried a different browser yet. For right now it seems to be back up and running. But it seems to be a recurring thing so I just wanted to see if someone had a solution for how to fix it or avoid it
Yeah I’m using chrome and it’s been great for me. But the issue is probably browser based. Haha. Darn technology. Thanks guys! I’ll try another browser is it persists.
I have not experienced too many issues with the GFUI until recently. Some similar to yours.
Here’s a list I’ve been compiling:
previously uploaded files losing the artwork. Someone suggested I had deleted the artwork. I accepted that on the first one, but it has happened 3 times now on 3 different files. It could still be me, given the old age, but I am having my doubts.
Set a cut operation for a file along with some engraving. The tiles on the left show the settings. Ran it and only the engraving completed. There was no cutting. Set engraving to Ignore and re-ran okay.
Six “Unexpected Error” messages when attempting to load a previously uploaded file.
“Offline” message after completing a run. Tried turning off/on laser, verified network was working.
I was thinking maybe had something to do with the latest release. Expect for having to reload the artwork, most of the time I can get things working again by either closing down Chrome and re-opening or doing a restart.
Or it might have something to do with the last Windows update I got last weekend…
Some of the Google and Amazon services have gone down over the last few hours. I would try waiting a little bit until everything is back online. Check for chrome and flash updates? I know that the GFUI does not use flash but it has affected loading for me for some reason.
You can check the statuses of Google and Amazon servers at the following locations respectively.
Thanks for letting us know about this. In addition to the suggestions above to try a different browser or restart, there is another possibility I’d like to check out.
Chrome updated to version 73.0.3683 on 3/12/19. Even if automatic updates are turned on, you may need to restart the Chrome browser in order to apply the update. You can click on “About Google Chrome” in the browser menu to make sure.
Could you please let me know if you’re using the current version, and if not, if updating helps resolve this issue?
