pete
March 20, 2018, 2:43pm
So we’ve had our Glowforge in the UK now for about a day.
Astonished by the accuracy of the cutting. It made blending some of the proof grade materials together trivial.
Noticed that it might be worth running a ‘score’ arount the edge of an ‘etch’ to remove the micro small jagged edge.
Is this possible?
Thanks
Pete
shop
March 20, 2018, 2:44pm
yup. i’ve done that a few times as well. gives a nice clean edge.
I never thought about doing a score around the edge to knock off the sharp corners. Good idea! This looks cool together!
pete
March 20, 2018, 2:54pm
4
Does the score cut past the etch point or will it work out the surface level is still the top of the material?
shop
March 20, 2018, 2:55pm
5
it does cut a little deeper. but you can always experiment a little and go manual and lower the settings if you want.
Jules
March 20, 2018, 3:43pm
6
Very nice! They fit together extremely well!
ptodd
March 20, 2018, 4:46pm
7
Great job … Nice to get a new piece of equipment and knock out a cool project so quickly!
Yes, that works well to have a bit better definition around an etch. You do have to make a separate object for the score that is placed over/under the engraved shape. Outline stroke defined with a color (or colour for you!) and no fill for the score.
Nice work! Thanks for posting.
