First attempt at engraving a purchased vector pattern from Shutterstock.
Box pattern from boxes.py - AngledBox modded to 1 wall per side
Went with draftboard - love the look of the outside but the look of raw draftboard on the inside is not great so some additional finishing steps are needed.
Next I will be attempting to measure and cut felt inserts and add rubber feet to make this ready for use.
Couple of notes,
- removing the masking was almost too much effort but after switching from fingernails to a razor scraper tool things went a bit quicker
- I didn’t really know how to dial in the engrave depth so on a second try I would make a shallower cut
- SD Graphic setting seems to be a good enough resolution for something that would sit on a shelf
