I’m working on a box design using the type tray module of boxes.py. When I go to look at the generated SVG file, I see that the tabs on the box have funny details. The outer corners are filleted, which is OK, I guess, but the inner corners have little details like maybe you’d use for a drag knife vinyl cutter. Zoomed in, it looks like this:
Questions:
- What setting in boxes.py turns this feature on/off?
- Is there a benefit to cutting the file like this? I can see the outer corner fillets making it a little easier to put together, but what’s the benefit of the inner reverse fillets?
- Do I need to get rid of these all manually?
Thanks,
Alec
