I have used the Brilliance spray on aluminum like people have suggested on here, but after I wash it under water and dry it, it seems to start coming off and part of the markings are gone. Is there something that you need to seal it with or is something else wrong?
Did you clean the aluminum with rubbing alcohol before you sprayed?
This question is outside our team’s scope. I’ve moved it to the Beyond the Manual so the discussion can continue there.
No I didn’t clean it with alcohol I will try that. Thank you.
