how do you round corners slightly? When I try to do it in inskape it makes the path for both sides warp and change?
By double clicking on the line you get a new node. You put a node close on either side of the corner and then delete the corner. Where you want straight lines, click on the line and the second to last option about lines on the bar is a straight line. If you pick that the line will be straight between the two joining points,
Thanks for reaching out. I’m sorry your prints aren’t turning out the way you expect.
Since you mentioned the issue occurred on Proofgrade Acrylic as well, would you mind providing a photo of the print on Proofgrade material as well as the date and time of the print?
This will help me look into the issue.
