Has anyone ever had an issue with your magic button all the sudden not responding ? Does everything like normal, flashes when it’s ready to print, but when I push the button nothing happens. Then, if I open the lid it doesn’t even sense that the lid is open…
The button alone would be reason to need to replace the machine. Never heard of the lid issue happening at the same time. They do not share any cables or connectors.
Yep, you’re describing two different problems. Not sensing the door open suggests the black lid cable which many have had a problem with.
By any chance have you just cleaned inside the machine?
