ButtonSsssentry.zip (8.9 MB) My version of the surround for the start button… This is a small print of my 7 ft boa named Kane.
The print is left a bit messy at the edges, because I knew it would be cut off when the file was cut out. You will want to put the button circle on Ignore, as it doesn’t need to be cut. I put that in there to get the sizing correct. Just make sure that circle is a tiny bit larger than the 1.5" that the button needs. That will make the whole file the correct size.
