Is there anyway to redo and skip ahead with the bypass? I cut 2 sections then hit the wrong button so I cant back up and finish the cut
Welcome to the forum.
I do not think you can bypass steps one and two to start again.
Great question! I’m not certain what you mean by bypass, but if you need to run your print again, it’s possible to ignore steps (such as a particular engrave or cut). Simply click on the step in the left-hand sidebar of the Glowforge app, then select ignore. Here’s an example:
I hope this helps! I’m going to close this thread. If you have further questions, you can post a new topic.
