I started my Glowforge today I haven’t used it for a month or so…
I see power starting, then I hear the fan for a few seconds, then usually the arm will move and start homing but now nothing happens. In the app it still shows as offline.
I tried on and off for a few times each time same result…
I cleaned the minimum… not sure if anything else needs cleaning…
Can you look in the logs and let me know what is the issue. You can contact me via email if that is what you think is best.
