Anyone else like to play camera alignment chicken? I know there are haters out there but Glowganberry has been so precise I just keep pushing my luck. Show me your close cuts!
Pretty Good, but you wasted what you saved at the top . I’ll root around my crops. Gordon cuts very close after running the camera alignment - usually within .015" so i get pretty close on some stuff.
Edit after checking my crops: You win.
Did #40 have a flat spot? Looks like the beam would have just about burned out the side.
It wasn’t waste, I couldn’t fit any of the pieces in there.
Also my time is worth way more than the pennies in material so the real waste would have been screwing around with it
(About $6 per square foot, that 2 square inches is about 9 cents )
Hi, my reply was to @Pheomelanin. How close did actual match the preview. Mine is scary close.
Very close match to the preview- I placed the design literally as far to the left as I could place it before falling off the print area.
I play this almost every day. I get burnt occasionally but mostly it works out. I giggle when I have a straight edge in the right place but with no laser burn. That means I got to within about a laser width.
