My son is in the Air Force and has asked me to make him a Missleman Badge. He really wants it to be something that can stand up on his desk alone. I’ve found an svg for it but it’s only a single image. Would anyone be willing to convert this into something I can assemble into a 3D project?
This is what the badge looks like. The SVG file basically is this but flat so it won’t stand
on its own. I didn’t attach a pic before bc I figured if someone was willing to help me I would just send attention for next time.
That might work as variable engrave just by making a negative of it,then you could have a stand glued to the back. That would be the easiest to accomplish.
Another way would be to make several pieces and stack them on top of each other and would still likely want a standing bit for the back.
I still very much a newbie and don’t have the first idea about making a negative. I was thinking maybe someone could help me to make it sort of like one of the art displays where you slide them together somehow to make it stand up and be multidimensional?
See if this works. Comes with no warranty, you get what you pay for!
Should print fine on “Medium” proofgrade materials. You’ll need a little glue, and the “stand” might need a little adjusting with an emory board or sandpaper. Suggest you check the fit before you glue the other layers on, in case the hole needs adjusting.
It did. It was just the lighting in my area & snapped a quick photo on my prototype Baltic birch.
Between working full time in a hospital lab where we get a ton of covid-19 tests (only time we’re considered essential lol), in school part time & being a military spouse, a military mom & a first time brand new grandma I haven’t
had a whole lot of time to learn vector programs. I’ve got then just haven’t learned them. This was the first time reaching out for design help & I appreciate the help more than you know.
