I’m trying to save time and use the Glowforge app Premium text option instead of designing text in Illustrator. Some fonts worked well with the outline feature but now I can’t get the “create outline” feature to see the “counter” areas inside the letters and cut those areas out. Any ideas? Ty!
All i can think of is you might want to check the size (width) of the outline you are using. If the “counter” areas are small, it might not show up if you are using too wide of an outline.
I’m afraid the only way to get at those counters from the Glowforge Premium fonts is to export the design and do it in some external software like Illustrator or Inkscape.
