Can’t go online
can’t go online
Have you worked through these troubleshooting steps? https://support.glowforge.com/hc/en-us/articles/360047722673-Glowforge-is-Offline
I have, with no luck.
Have you tried holding the print button down until it flashes teal and gone through the setup process as you did when you first got the machine? You can also try using your phone as a hotspot and going through the setup process.
I have, but will try again shortly.
