Can the Pro cut something with a similar density as ceramic tile?
Not cut but it should be able to engrave it depending on the material. you run into issues tho sometimes with rocks that have a larger grain structure where it can do some weird fracturing depending on the settings.
Thanks!!!
Check out results people have gotten on slate tiles, some of it is mind blowing like this one from a google search.
