I ambitiously purchased a glowforge pro, thinking I’d draw a picture and cut a design. That’s proving to be more challenging than I expected. I need to create a display for my product. I have a drawing but need help creating a design file.
Can you recommend someone to help with this? Also, how long does something like that usually take?
Unfortunately, I don’t have the time to give you a full answer about your question, but I did want to say welcome to the forum. I’m sure other people will be along to give you a more detailed answer here, but if I were in your shoes and if time were a factor, I would be looking online to try to find an existing design for display that I liked and then modifying it with whatever image you’d like to add to it.
This can sound a little complicated when you are new to everything, but I’m sure with a little bit of help from your new friends around the forum we can give you enough pointers to get you going.
The answer to that very much depends on the complexity of the design, and your experience with a design application.
I have spent minutes workin on simple things like a stand for a phone or tablet, and many hours over several days or even weeks working on complex items that often require testing/trial fitting that use mating surfaces.
