when I try to change the material thickness the box will not let me enter a thing.
Have you used set focus? That will allow you to just forget about manually setting thickness.
Welcome to the forum.
You enter the material thickness in each operation if you don’t want to use the set focus tool. Click the operation (cut, score, engrave) toggle to manual, and enter thickness.
try refreshing the bed image , its in the 3 dots above set focus, or refresh the entire browser page
Thank you!
