Can't etch/engrave on a 1 inch circle it's not centered
So I’m trying to engrave a name and circle/border on a round 1 inch circle. I get it all lined up use the little option to focus the laser in a particular spot, I have the circle directly below the camera lens, tried in all different areas of the board but every single time it is shifted off to the left about 5/32 of an inch. When i move it to different place it’s off different amounts but it’s always off to the same side. What in the hell is going on??
I then did a recalibration of the machine. And it’s still off but now it’s off the same amounts but going straight down and not off to the left. Now when I try to use the focusing tool it keeps giving an air now that I’ve recalibrated the machine.
I thought you were supposed to be able to engrave etch on basically anything So why can’t I do this on a one piece of material. I’m not trying to cut out a one inch piece of material I already have one inch pieces of material in circles.
I read that you need to have a jig that you place the item into to cut. For example a pre-cut circle that my circle would sit into. I tried this, one time it print perfectly but then I open the lid and moved the jig as I would printing different times for different circles and again it’s off. I don’t get it
Never move the jig. That’s the key.
Here’s my breakdown of jig techniques.
The jig will insure that your items are precisely centered. Make sure the circle that outlines your 1" circle and the design you want engraved are in the same file and that your design is centered as you wish. Put a piece of paper or cardboard on the bed of the interface and load your design. Cut the circle outline and ignore your design. Don’t move the paper or cardboard. Place your item in the circle cut out. Ignore the cut line and enable the engrave. Set focus on your item. IGNORE THE CAMERA VIEW. Click print. The engrave will be where you wish and will be in focus.
Exactly. This is method #2 in my faq link above, a “pocket jig”. If you want pictures illustrating this method, it’s all spelled out there.
Yep that’s the way I do it!!! works every time.
Me too! Simplest way to get it right.
Thanks for the info. What are the settings for cardboard cutting, like a cardboard Chewy box?? I don’t know how to use any of the custom settings I’ve only ever used proofgrade glowforage materials. Also how do you determine other settings like for a dog tag, Aluminum or stainless steel engraving.
Just about any settings question can be answered by this post:
I just use a scrap piece of cardboard. You start with an svg that has a circle for the disk shape in one color and the design to engrave in a different color. Place the scrap cardboard, hold it in place with magnets, and cut the circle out. Then, without moving the cardboard, slip each disk into the hole and engrave.
I have always taught my girls. “DO THINGS THE EASY WAY”
yep, a panel from a Chewy box would be fine. There are actually two built in settings for cardboard in the professional models, Basic, Basic Plus, Pro. Choose whichever one matches the cardboard you use.
