Hi everyone. I’m following the first print tutorial and printing the ‘Magic of good measure’ file. But it’s erroring at ‘Calculating Precision Movement’ every time. I’ve tried restarting the GF and browser a number of times.
Also the scanned image is pretty blurry and only recognising the barcode about 50% of the time.
I think the GF has better luck reading the QRC if its a little further away from the edge. But all the sample wood I have at the moment is pretty wide and the code can only be on the edge. Here is a screenshot…
Are you able to use the Set Focus function? It is behind the gear in the upper tool ribbon. Click it and then click in the middle of the material or over the QRC.
Wow that’s a really badly placed QR code. They almost always an inch or more inside the edge which allows you to flip it. But that’s why you can pick the material manually.
Unfortunately, it looks like your unit is experiencing an issue that we can’t resolve remotely. I want you to have a reliable unit, so I’m recommending we replace this one. I’ll be in touch via email to sort out the details. I’m so sorry about the bad news.
