Cartridge plate replacement
i have replaced the cartridge plate and still receiving yellow light. the fan on the catridge plate is not moving. Can someone please help before monday comes along. i understand the office staff will be out until then.
When you say “the fan on the carriage plate”, do you mean the 1/2" fan underneath, or the ~2" fan at the back?
If it’s the one at the back, there is a small clip that plugs in to connect the wiring - make sure none of the metal wires in that have been bent or broken. If you’re not sure, you can take pictures and post them here.
That fan gets its power from the head, so as a troubleshooting step be sure of the ribbon connection to it, and clean the pins on the carriage plate that the head connects to.
