I am trying to make some “usefull projects” . I am also playing with the proof grade clear acrylic, which by the way, cuts like butter. I can’t say enough about how easy it is to work with when using the proof grade settings. Anyway, here is what I made.
I figured out why there is some blow back on the top edge of the acrylic; it was because my pattern had the top cut twice, my bad. The flash makes it show up, but it is not that obvious in normal light.
