Interesting. It’s what I thought.
And this is a good bug report for GF.
Your SVG uses the <use>
tag, which is used to reuse a defined shape elsewhere in the SVG.
Pixelmator embeds your bitmap as a defined <image>
, and then uses <use>
to position it.
It seems GF incorrectly ignores attributes on the <use>
tag and instead just uses the attributes on the <image>
tag.
The easiest fix, is to not use the symbol definitions and the <use>
tag. For your workflow, I’m not sure if you can get Pixelmator to export differently. If you screenshot your export settings or whatever, maybe I can give you some guidance.
But at least for this file, I fixed it manually for you, in two ways.
The first, I just removed the <use>
and put the <image>
directly where the <use>
was.
The second, I put the x
and y
attributes from the <use>
on the <image>
in the definition. This actually renders incorrectly everywhere else, but worked correctly in the GFUI, which is maybe further evidence the GFUI has a bug.
@GF Staff folks… if there’s a better way to file a proper bug like this, let me know.
Anyway @designatednerd, here’s two fixed version for you, I’d recommend the first:
pollo_coaster 2-fixed.svg.zip (10.3 KB)
pollo_coaster 2-fixed but also broken.svg.zip (10.3 KB)
